Article: Handz
slow5poh
What kind of exhaust are you running? That configuration at the rear looks different than the over the axle type. looks good
[MENTION=19718]slow5poh[/MENTION] I believe it's a Magnaflow catback for 03/04 Cobras.
Ballistic
Oregon
I think that's Greg's mustang from Chemical Guys, Its has a IRS Swap, w/ Magnaflow catback for 03/04 Cobra
Oh. So it probably won't work on a SRA 98 gt
It will fit actually. It's been done multiple times. However it does not allow for the rear suspension to travel. The axle will probably bend and possibly rip off the exhaust the first time it gets enough travel. You also wouldn't be able to jack up the car from the rear unless you raise up the axle too. Any rear droop and that bad boy will cause issues.
But to answer your question, yes it will fit on a SRA.
senior001
