bad radiator?
MrNiceGuy
well my car started to overheat last week so i turned it off immediately and i havent had time to work on it until today.. so i replaced the coolant temp sensor since it was broken in half for some reason and i replaced the thermostat.. the car doesnt overheat anymore but there is smoke coming from the radiator.. i havent seen any leaks anywhere throughout the coolant system.. the water pump is not leaking either... so i have a bad radiator correct?
mustangshane
Powhatan, Va
I'm going to go with yes. Mine does that from time to time when its colder. They leak around the end tanks if I remember correctly.
+1. ive seen most problems on the passenger side (personally)
are you leaking on your garage floor or anything?
Mean98GT
sounds like its toast. my coolant temp sensor broke in half as well!! it looked like it corroded. is that what yours did as well?
