Balljoints & Tierods Q
Matt94GT
2 part question. I want to think ahead here.
Tierods.
Mine were squeeking pretty bad three summers ago, I have not had an issue since I injected some lube into the outer? tierod joint boot?
Im afraid that they are probably now getting dirty from the small incision I made and will start causing issues again soon.
What should I replace them with when the time comes? Keep in mind my car is pretty damn low, about 2.25" in the front. I am running offset rack bushings, as far as I can remember.
Im also thinking a bumpsteer kit...?
Balljoints.
I would like to replace these at the same time, might as well while im in there. I was going to get 03 Cobra A arms a few years back when they were $160ish they are now $300...at that time it was cheaper then getting new balljoints and getting them pressed, but now its doesn't really matter. I know the Steeda X2 were popular YEARS ago before the 03 cobra a-arm fad came in, just wondering what you all think my best option is for this, keeping in mind my low ride hight.
ps: for what its worth right now my car loves to follow tracks on very worn roads...
Slykin
Tyler, Texas
Are you doing this yourself or are you taking it to a shop? I'd personally recommend Federal Mogul Problem Solver balljoints, they are substantially more heavy duty than the stock ones. I've had mine in for at least 10k with absolutely no problems.. though that doesn't mean much. As for the Tie-rods, I have no clue.
330CubeGt
Ball joints are roughly $30 for both i just did the inners/outers and balljoints and picked up a kit on ebay for everything for $75 SHIPPED and installed myself. If you have the correct tools to press in the BJ you should be able to do it all at home in 2Hrs and just take it up to get aligned after the fact. Just remember to count the amount of turns you take the bump steer kit off the inner so when you put it back on its damn close to the same spot it will make driving the car to get aligned alot easier.
Matt94GT
Matt94GT
More then likely ill get my friend at his shop to do it. Or a suspension place, that is if I get a bumpsteer kit as well.
rz5.0 said:
Looks like you have a bump steer kit. So you dont have an outer tie rod.you r pic points to the ball joint
That pic is not mine, I do NOT have a bumpsteer kit. I just realized that pic I posted has a aftermarket K member so ignore it lol.
Help me clear this up with the pic below (off steedas site)
Correct me if im wrong:
#1 = Bumpsteer kit, which replaces the outer tie-rod, which replaces the issue I have with the squeek (OEM has a boot...correct? I swear this is where I injected the lube)
#2 = Balljoint (OEM do NOT have a grease nipple/non greaseable?)
I was thinking of getting a bumpsteer kit as it would solve my need to replace my outer tie-rod ends? Hows the bumpsteer kit work exactly? I know it corrects the geometry but looking at the above pic I dont really notice it?
I was thinking:
Bumpsteer Kit
X2 Steeda Bushings
but not sure. also like I said this is just research so when the time comes I can replace them. no point in doing anything I assume until I get the popping from the balljoints or more issues with the inner tie rods (there ok as of now) right?
ryclef331
You outer tie rods or bumpsteer kit can be replaced very easily without much labor. Balljoints are a different story. You can do the steeda X2's but unless you're planning on using them to lower the car, a set of MOOG balljoints from the parts store are your best bet. Federal Moguls are ok...MOOG is top quality. You can use a balljoint press that will make life VERY easy...or a BFH (BIG F**KING HAMMER). The hammer method takes some finesse to not mess up anything.
Matt94GT
Matt94GT
Ok I was under the assumption I had to take most of it apart for the bumpsteer kit, maybe ill do that first then.
I thought the X2 steedas were made for cars that are lowered? If its all just a crock im sure the MOOG's are a lot cheaper. And yes ill use a press :)
Slykin
Tyler, Texas
Pretty sure MOOG is a sub-branch of Federal Mogul or the same thing. So, if you get Federal Mogul it's really a MOOG. At least that's what I understood from the Federal Mogul Website. If i'm wrong feel free to correct me.
Insayne
federal mogul is the marketing company. they market moog, national bearing and seal, fel pro gaskets and so on. The moog problem solvers are stout. I would go with a bumpsteer kit and find the thread where handz came up with a far improved end for the kit for the best outer tie rod setup as for a ball joint i cant say anything about the x2's but the moogs should do very well.
Matt94GT
Matt94GT
thanks hopefully he will chime in here.
rz5.0
Great state of TEXAS
Bumpsteet is real easy to replace scince your there you should think about the inners.
Im kind of cheap so I always get the store brand with life time waranty I dont mind since I replace my self and im always switching something aroud so I replacle even if not needed just cause I dont have pay for it.
Shifty Powers
Where the wild goose grows
i posted about this like 2 weeks ago.. and got one response lol.. damn.. well this helps me out a tad..
ill prolly get the bumpsteer kit and the X2 balljoints.. but do i have to get the balljoints if i go with a new LCA from MM??? prolly do..
What about Billet Steering Rack Bushings from steeda? Seems like it makes sense, but will that kill a kinda DD car that will hopefully see auto-x and open tracking?
Guess i can just talk to MM
Slykin
Tyler, Texas
I got the solid steering rack bushings for my car that I DD 50miles min. a day.. NO problems at all with the bushings and they take away a bit of the "smush" in the steering. I highly recommend them.
rz5.0
If you get new a arms they should come with ball joints. Lca's go in the rear.
red95r
SUGAR LAND TexSuhZ
I just finished doing front end work. I put in the MOOG problem solvers. These things make OEM look pathetic. I should've done the tie-rods but ran out of money.
Shifty Powers
yes but then the X2 would still be better probably than what comes with it.. And you knew what i meant, i knew what i meant. Fronts are still control arms.. just FRONT control arms, sorry, not lower. I know lower is in the rear. But thank you
And thank you all for the input on the solid bushings
Matt94GT
Matt94GT
Thanks guys, Ill check out some local pricing on MOOG, if its near the same price as the X2 might as well go that route I assume?
Also yeah I might as well do inner tierods while im under there, thats what I was getting at I would rather replace stuff while its apart and Im in there.
Are there different choices for inner tirerods?
Insayne
Standard replacement stuff. I'd go with the moog problem solvers with a bumpsteer kit
Dws 95 mustang GT
