Battery Relocation help
97stanger
As some of you know, I am in the process of doing some pretty major work to my car. I already am in the process of doing the valvesprings/retainers, then putting the blower cams in. Next step will be to order the Snow Performance stage 2 meth kit with solenoid upgrade. While doing this, I am going to be relocating the battery to the trunk so that I can mount the meth tank under the hood where the battery sat.
I was originally going to go with this Taylor relocation kit and a kill switch from Jegs. Now the Taylor relocation kit is about $200 and the kill switch is $50. So as you can see it wont be THAT cheap of a little project, about $250
http://www.summitracing.com/parts/TAY-48204/?image=large
http://www.jegs.com/p/JEGS/JEGS-300A-Master-Disconnect-Switch/1016943/10002/-1
Now while doing some more searching, I was on American Muscle and came across this battery relocation on sale during the month of October for $100 and a kill switch for $30. So $130 said and done.
http://www.americanmuscle.com/taylor-batterybox.html
http://www.americanmuscle.com/taylor-battery-disconnect.html
For the $99 one, it does say "taylor" on the relocation box and as well as on the switch. It also says that it is acceptable for all NHRA rules, so will this kit be fine to use and save me some bucks? thanks guys
97stanger
97stanger
it looks as though no cable is included though. hhmmm, im not too suave when it comes to electrical work, but how much should cable run me, and what guage should i need? how long?
duff daddy
the lower the gauge the better, i would just buy the kit and spend the extra money that way if you have issues its done by a company who will stand up behind it
dafizuck
+1
duff daddy
and it looks better should you car go up in flames and they blame it on chucks battery relocation kit
Traidmarx
we did it in my friend 97 cobra...we used a zero gauge wire, i think we got 10 ft. i would suggest 12. because it were cutting it close with wire. there are two rubber stops in the bottom of the trunk under everything. we took the drivers side one out...and ran the wires down through there, and along the underbody of the car. and ran them up to the original ground and power wires, and bought clamps to keep those together, then ran 2 10 guage wires from those neg. and pos. posts down to the starter. and it worked perfect.
97stanger
97stanger
well, the $99 one from American Muscle is made by Taylor as well. It looks to me the only thing it does not include is the wiring....
95PGTTech
I have that JEGS switch and it was defective out of the box. It wouldn't kill the car except in one small window position. You'd flip it to off and unless you wiggled it around you couldn't find the dead spot. Check it with a multimeter when you get it.
95opal
I would just go to a welding supply shop and grab some 1ot wire as far as the box goes you can have one fabricated to meet your needs. The kits a pretty lame INHO i bought one and never used it.
blown98gt
You realize you don't have to relocate the battery for your snow kit right? The kit comes with instructions on using your windshield wiper tank to hold the meth mix and I put my pump in the driver side fender, it would've been a lot easier i'm sure to use a battery relocation kit and put it all there but my kit is hidden so if you didn't know any better you'd never tell i've got a meth kit.
The taylor kit is way over priced, but the cables aren't as expensive as you think. I can't remember the exact price but 1g wire is like approx 30 bucks for 10ft might have changed but last i remember it was a bit high so might want to look into wire too before you buy a kit.
95PGTTech
tommybunz said:
i used a autozone box with my taylor wire kit it looks nice. $7 box fm the zone
if he goes to an NHRA track (of which the closest two to him are) he won't be allowed to run set up like that.
95PGTTech
Yes, a wet cell does not require the same box/breather rules. It still must pass the shake down test though.
