battery relocation
94yellow50
illinois
hey guys come next spring when i get my car out i wanna move the battery to the trunk of my 94, just to get some weight off the front and to start to clean it up in there some. wondering if anyone has pictures of there setups in there SN car. ive seen plenty in foxes but was wantin to know how anyones run a cut off switch to the outside. just lookin for some info specific to our body style. thanks guys
Venom351R
Maine
My cut off is behind my licence plate, cant even tell I have one there.
94kingcbra
get at least 2 guage, and a decent battery, because when you need to start it, the electricity has to run 20 feet now instead of 5. I ended up putting a red top in my engine compartment for starting because I had some close calls. I have a yellow top in the trunk. Also make sure you get a good chassis ground. I drilled through my floorboard, and connected it to my frame, and make sure you use grommets any time you are going through sheet metal, especially the power wire. I can take some pics tomorrow if you like.
I agree with venom, on the location for the cut off, I've seen people actually cut through their license plate and put the kiil switch in the middle so it's always accesible, or you can put it in the key hole, and just rely on the trunk button or your alarm clicker to get into your trunk. The lock is easy to remove, and it would be easy to put back, and you would never have to drill. my $00.02
Venom351R
Maine
94 DropTop said:
So how did you wire yours all up? I want to move my battery this winter.
I didn't, I hate electrical work. Friend of mine did it at his shop.
94yellow50
94yellow50
illinois
vemon, i like how you have that, ive seen that done on foxes with it hiding behind the plate and im thinkin thats how i will do mine, mostly because that way no one can mess with it if its parked somewhere, and i didnt feel like cutting up my tail lights. as for the wire, ive heard 1 gauge welding wire is a very good thing to use, anyone here have any imput on that? as for battery its a brand new one but its nothin special, think it was a autozone one or somethin. should i be too worried about that for now? i literaly just put it in this past spring when i got the car out. if its a problem its not a huge deal.
Venom351R
Maine
If its a new battery you should be fine. I pretty sure 1 gauge cable was used on mine
94kingcbra
oh, also when drilling through the floor make sure you remove the gas tank before you start! You will have to tighten bolts anyway, I did mine when I replaced my fuel pump, so i didn't have to drop the tank twice. Good Luck!
94yellow50
94yellow50
illinois
yea ill probably just go ahead and do some preventative maintence and put a new pump in while its down..and yea definatly be using gromets any where theres a hole the wire goes through. i have a buddy that built a fox to drag race so hes done all this stuff before and im sure ill be havin him help along the way just to make sure it gets done right
tommybunz
i did mine similar to venom but i had my switch between the plate bulbs. a much cleaner discrete look but you will have to cut the trunk a little
Venom351R
Maine
yeah cutting the trunk is the only downside to it but on the other hand its something thats never seen unless the trunk is up.
94yellow50
94yellow50
illinois
just curious, will that pass track tech? since it would be up there kinda hard to see. just wondered, i dont race more than 4-5 times a year and its always just TnT, so i wouldnt think it would be too strickly enforced.
Venom351R
Maine
Yes it will pass. Just have to have the plate removed during racing so that the switch is visible and accessible.
94yellow50
94yellow50
illinois
you dont happen to anothe pic from the back lookin towards the car do you? if not no biggy, looks like a nice clean install tho. also, the T-handle that sticks out, is that threaded so you can unthread it so no one can mess with it? or is it just there for good?
chrajohns0
I have one to install from summit, and i am wanting to know if i need to get a battery pad to put in the box?
