Electric power steering info
shovel
I'm sharing this in case it helps someone else in the future.
Before we get started I want to get two things out of the way: 1. this Mustang is a high mileage "rescue" so I'm not concerned with preserving its museum or collectible value. Its value is for me smiling while I rack up miles. 2. I am not good at welding, I need more practice and this is practice.
I chose a Volvo S40 power steering pump because these are massively available and it's a swap that's been done hundreds of times on vehicles of every make and model, so I didn't have to invent anything there.
These can be junkyarded or bought new from the usual alphabet soup overseas manufacturers pretty cheap.
I opted to get one that has the bracket included because that takes care of the rubber isolators and the basic shape of a bracket, so all I have to do is grind off paint and weld up random debris to fit my Mustang.
I have already relocated the battery to the trunk, so the area under the previous battery tray in front of the driver side front tire looks like as good a place as anywhere.
After lining up and measuring where I want it to sit I used a 2.75" hole saw to punch a hole in the metal below the battery tray:
Here's the basic look of the bracket, I did end up further modifying it after this photo (spacer on left side, as viewed from this angle) but the idea is about the same, if you're copying my work you'll have to kinda do your own thing anyway. I believe in you.
The left side of the bracket, viewed from this angle is the forward side of it and bolts to a pair of M8 rivnuts in the side of the radiator support loop. The right side of the bracket (vehicle rear) attaches to a single M8 rivnut mounted in the frame rail below the former battery tray. I had planned two but an inconvenient hole was already there from the factory. It feels quite rigid, the forward bolts against the radiator support do a good job of managing the vertical load so it is unlikely to vibrate or suffer under rough roads, pot-holes, etc.
Note that I am in the middle of other work unrelated to the electrical power steering so the engine bay + wiring is very messy for now. I'll post cleaner finished photos when it's finished and cleaner.
Here is the position of the filler cap while mounted in its final, permanent location.
shovel
shovel
As for the hydraulics, the factory SN95 high pressure hose does thread into the Volvo pump, I don't know if it would seal but it threads in - however there is not really any clean way to use the hose because of its length and the shape of the rigid end.
I opted to order a set of 6AN fittings for the rack -
and a similar 6AN fitting for the high pressure port of the pump. Then I'll figure out how long the hoses need to be and if they need 90 or 45 degree ends. To be determined.
Electrically - it requires a lot of current. In the Volvo it was designed for the pump is commanded by the powertrain control module to run at different levels of boost so it draws as little as 15A and as much as 80A supposedly - but in our application there's not a simple way to tie it in to the vehicle speed sensor. Instead there are two options - either connect it straight to switched power and it runs in a fixed fail-safe mode supposedly around 70% max, drawing around 40-50A continuously or else connect it to a 3rd party control box with a knob and you can use the knob to dial in your preferred level of assist.
The controllers are about $60.
Because of the high current draw I wanted to make sure it would only run while the engine is actually running, turning the alternator. So I added an extra oil pressure switch that will complete a circuit only while the engine is generating oil pressure.
I have NOT completed the electrical hook-up yet because the pump needs power steering fluid in it first, it can be damaged by running dry. I'll post more once I have the install finished and can share what I learned in the process.
Another detail to mention is the bracket and pulley routing. I have deleted the secondary air pump and I am also converting to electric air conditioning. I've also relocated the alternator to a low position where the secondary air (smog) pump previously was located.
With the power steering pump + A/C compressor bracket removed there is nowhere to mount the ignition coil and also the belt does not wrap around the water pump very well.
This bracket from Speed Doctor relocates the alternator to a low position and adds an idler pulley. This allows a physically larger alternator to be used & avoid clearance problems with the valve covers on a 94/95.
Unfortunately this results in very little wrap around the water pump and I don't trust it to turn the pump without slipping under all loads and temperatures and conditions.
So as a solution I cut down the old power steering pump bracket:
This provides the place to mount the ignition coil (OE or aftermarket) and an idler pulley. The OE pulley is smooth (back of belt drive) but can be swapped out for a 6 rib idler. The axle bolt is right-handed so if the bearing seizes it might unscrew itself but you already got problems if that happens.
shovel
shovel
For anyone who might be wondering why do this in the first place, I mostly just felt like it. Maybe it will end up being dumb, won't know until it's done.
The general idea is that it allows tunable steering feel and it decouples engine rpm from assist level. I assume the reduced rotating mass will make the engine feel more lively.
cobrajeff96
Germany
One thing you might have to revisit is the relative assist to driving speed ratio. Some might be ok with constant effort level even at higher speeds. I myself prefer a stiffer wheel at higher speeds. Mostly a subjective assessment.
Keep us posted on your electric A/C goal, that sounds cool.
shovel
shovel
The engine driven pump is presumably producing more boost at highway speed (2500+ engine rpm) than parking lot speed (barely over idle) so if anything a constant speed should be an improvement.
Since the engine controller doesn't have any idea what the car's road speed is there's not a good way to get commands from that and I'd rather not dig into the speedometer cluster just for this, so hopefully it's not difficult to find a single good setting that feels right to me and leave it there.
The control box has a potentiometer for user input, you just dial in your desired boost. I haven't checked its value but I expect it's 10k or 100k and that means with a little trial and error I can find some favorite settings, measure the value of the pot and then replace it with a resistor. That also means someone else who doesn't mind building a monster could use a GPS activated relay to switch between two different resistor values at a predetermined speed.
I'm better with a soldering iron than I am with a welder but I don't want to introduce that level of complexity
Electric A/C is coming after I finish making the car driveable.. just in time for the heat of summer.
cobrajeff96
Germany
You can vary the output potentially quite easily. For instance, I've doubled the use of a Samoco T-56 Reverse Lockout Module from Wirebarn as an electronic parking brake failsafe (it activates only at very low speeds and de-activates right around 20mph from what I've observed during actual driving). The same speed sensor can tap into pretty much any SN95 transmission (just uses the gray and pink wires on the existing transmission speed sensor) and this way you don't have to reach for a dial or switch every time you pull up to the driveway or into a parking lot.
And there's loads of people on places like Adafruit and Sparkfun that have done mods like these. You can get crazy and go with Raspberry Pi if that's your thing, but it may be unnecessary.
kas_lar
Great work, Shovel! I’m thinking about doing this upgrade as well.
My battery is still in the stock location, so I need to figure out where I could mount the Volvo pump without making the engine bay even more stupidly crowded than Ford already managed.
Do you have any other guides, photos, or links for this conversion? I’m especially interested in pump placement, wiring, fittings/hoses, and how people route everything with the stock battery location.
shovel
shovel
I guess you could put the power steering pump in the back.. or there's room in front of the passenger side tire there just isn't really a way to access it to fill or inspect levels.
shovel
shovel
I don't have a full story to add here but while I'm thinking about it I figured I would add this -
6AN fittings go into the steering rack, replacing those miserable OEM 90 degree fittings that are almost impossible to get a wrench on without removing the rack (and unpleasant even if you do that) - these just go right in. In fact if I need to ever take the hoses off my wife's New Edge I'm going to convert that car to use these as well, those OEM fittings can go somewhere under hell.
I happened to have two 32" 6AN high pressure rated hoses from a previous project and plumbed it together with the cooler that way, but the hoses are much too long and kind of annoying to deal with the extra length because of how stiff they are. After I have everything together and working properly I'll replace them with hoses of an ideal length, closer to 24"
This next part might be useful to anyone wanting to do the same thing in the future:
On this car (1994 GT) the oil pressure "gauge" in the dashboard is a lie. It's more like an oil pressure presence indicator that's shaped like a gauge. The sender is a switch so after the oil pressure gets above a few psi it shorts to ground and then the needle in your gauge cluster.
That also means if you want to trigger something electrical so that it can only run while the engine is running you can use oil pressure. The idea is if the power steering pump runs whenever the key is in run, whether or not the engine is running then it could very quickly run down the battery. The same will be true with electric air conditioning, maybe if you switch to an electric water pump, etc.
What I did not know was if I need to install a second oil pressure switch or if I can just piggyback off the same one that's already there. So I wired a standard 12v automotive relay to +12v and the oil pressure gauge signal circuit. It ended up working perfectly, both the gauge and the relay work properly off the same sender, the 12v across them doesn't appear to cause any problem. Cool that means I don't need any extra parts.
shovel
shovel
I haven't updated this in a while because I was working on a lot of other things..
Here's what I have to add at this point -
It all appears to be working, I'm going to wrap spiral loom around the wires to give them a bit more vibration and abrasion resistance. Remember these are largely enclosed by the wheel well liner so I don't anticipate a huge amount of moisture getting up there as long as I don't just go tearing through standing water.
It was necessary to do a little trimming (roughly the area of a dollar bill, but a triangle) of the fender liner at the bottom near the frame rail to clear the pump and bracket.
After I take this thing for a few drives and get a feel for the "volume knob" and where I want the assist level to be I'm going to just measure the resistance across the knob and replace it with a resistor. That's why the knob is not mounted in any kind of weatherized situation - it's only in there long enough to evaluate it. Maybe i'll go nuts and get two resistors and a weatherproof toggle switch for 2 different levels of assist. What I'm not going to do is complicate things any further than that with wires through the firewall or GPS stuff.
So far inside my garage with the hood open I can't hear the pump over the engine idling unless I get close to it. Hopefully that fact remains when everything's buttoned up for daily driving.
shovel
shovel
I've got about 30 miles of mostly in-town driving done and with the control knob at its maximum setting the power assist is still less than the belt driven pump generally delivered at parking lot speeds. It always feels a little less assisted at every speed - there's also an odd little hump of resistance when beginning to demand power from it, like a PID controller catching up to demand. It's trivial and doesn't cause me any concern but it's a different flavor than the belt driven pump.
I didn't take note of the control pot's value (is it a 10k? 100k? I have to take it back out of where it's mounted to find out) - I think I like it either all the way up or maybe 90% of the way up. I'll just disconnect the leads from it, measure the resistance with a multimeter and buy a resistor of the appropriate value. All the way clockwise might just mean 0 or infinity ohms which would mean no resistor needed.
Mikehonco69
