Beeping noise??
BlackCobra50
Ok... So when it's really cold outside and my car has been sitting overnight and I start it for the first time that day... My car beeps, as if something with the gauges is messed up (I dont know if any of you have tried removing a gauge bulb ie. check engine bulb, and started the car and it beeped) its like that until the car warms up... I don't know why it does this... Any help??
CA.
blkmcnasty
Illinois
My car has two seperate beeping noises when i start the car- First one is just the typical key in the ignition chime and the right after that the seat belt chime comes on and is f-ing annoying. They are two different tones, do you think your beeping might be one of these?
B
BlackCobra50
When I turn the key, the ignition chime doesn't beep... and it never beeps for the seatbelt... so idk
mine does the key chime. thats it... or when the door is open and the key is in...
is it a beep? like pressing a button on a cell phone? lol. or is it a chime, like the key or door?
B
BlackCobra50
It's like a beep from the gauges... Same thing happened when I removed a bulb from the cluster and started the car.
8bangin302
i know this is an old post but does anyone know what hes talking about because mine just started doing it,and it started happening when i pulled the light bulbs out of my cluster,i was replacing all the bulbs cause most of them were blown.
Anyone.
it is a warning to tell you that one of the lights in the cluster is not working, such as a warning light. If you have pulled the airbag or any other light it will do it.
95GtStang420
The beeping is from the Air bag computer,its a blue box behing the radio....its beeping because it knows the lite is open circut...If you have none functioning SRs then just unplugg it.
