Belt
sxyxc
Ok, so i have a little money for my car... and the one thing that really bothers me right now with it, (besides the brakes which i am fixing also) my belts squeel when i am really on my car and it changes gears.. really annoying.. what can i do?? I have heard that gatorback belts are really nice.. ohh also i am about 1000 miles from 100K should i change the belt just because that reason??
gt96stang
When was the last time you changed the belt?? I would say do it anyways.. They aren't that expensive.
Jrgunn5150
Yes change your belt. and yes Gatorback's are nice, I think it's around 35 bucks.
sxyxc
got the belt, i will respond later tonight to see if it still does the squeel.. don't worry though no racing!! from a light on the highway to speedlimit is enough to tell and have some fun!!!
voidfinger
i got a poly cog bet from advance... it was like 45 or 50 bucks but it was pretty nice... who sells "gatorbacks" ?
Also, could the problem be the tentioner not holding it ??? or it might be weak??? I still have that problem after changing my belt
sxyxc
yeah, its Goodyear... i got mine at my local Auto Zone for $35ish....
realitygt
put some wd40 on some of ur pulleys but make sure not to get any on the belt or the surface where the belt rides.
ripper
I use Gates. 40-50 bux dunno. I have seen many posts on tensioners going bad. Must be a reg prob. NAPPA FTW
scarface
Guest
Def. My tentioner chirps when I first start up, those things are a def. weak link.
Goldmember
Cornwall, NY
There was actually a Ford TSB for the tensioner, they get weak over time and the arm on them "bends" a little bit which of course affects how the belt sits on the pulley. I put a Gatorback belt on my car, definitely worth the money.
I had to replace the idler pulley on the tensioner and the one in the timing cover, I had the dreaded squeal too- pretty easy job. Did the Gatorback at the same time.
voidfinger
well i can squeese my belt right below the alt. and so i thought the tentioner was bad so i replaced it today... I can still squease the belt... and it moves considerably... what do you guys think... time for a new belt? So either a gatorback, or a gates... what store can i get the gates from...
voidfinger
So do you think that is the prblem then? b/c other than the tentioner what else will cause the slackness other than the belt?
DropTopPony
South Jersey
Yeah the newer tensioners are stronger then what we have. Mine are still in decent shape though surprisingly.
