Best H/C/I ??
New 5.0
I will Start This Project In DEC.08 "302 To A Stroked 331" What Type HCI Will I Need?? If You have done this type of work or just know what your talking about PLEASE SHARE
Paul
THere is no best. What's your bugdet? Intended usage? Drivability requirements? Goals with the car?
1quk50
personal fav. is the trick flow ive seen big number put down outta 331 with trick flow top end kit...
and the eldabrock is so bad either...
LAFENATU
If your building a 331, I would not even bother with a AFR 165/Trick Flow Twisted Wedge head.
I would go right to a AFR 185 head, Edelbrock Performer RPM II, and a custom cam from Ed Curtis or Jay Allen.
Stopsign32v
I'm building a 331 with Twisted Wedge heads and an off the shelf cam and I'm willing to put it up against anyother street driven 331/347. :thumb:
Or Paul's 418W for that matter. :rollinglaugh:
N
New 5.0
Why not bother with the ones you mentioned?? What kind of numbers would i see from the setup your talking about (RWH)?
Stopsign32v
The 165s are just too small of a head and they will restrict you from growing in the future. The 185s cost the same or right at the same as the 165s and will make ALOT more power than the 165s will. Cutting the pistons and going with the 185s over the 165s will give you quite a bit more power. Not only at peak but all across the curve and the biggest part....you can grow later and not have to sell the heads and buy new ones. I'm telling you this because I didn't listen to most and it ended up costing me quite a bit of money when I went to sell my 165s to go bigger.
Paul
Let me know when your puny 331 makes 442 ft lbs of torque n/a at 2600 rpms. Douchebag. :)
Paul.
Stopsign32v
Paul.
Who races at 2,600rpms? :rollinglaugh: Where are you located? If its possible to run our cars I'd love to! :happydrunks: I'd put that video on every car message Forum there is. :hammer:
Paul
It makes over 400 ft lbs through nearly the entire RPM band actually.
If your car runs faster than 12.88 @ 111 mph, then you're faster than me. Pretty simple. My car's not fast, but I'd still take it over your piece of shit every day. :)
Paul.
Oh, and you should post more pictures of your blown cobra. It's weird that you don't mention owning it on any other forums???
Stopsign32v
I've got it listed in my sig on SVTP and Mach1reg. :coolsmiley: Its going back to get retuned and alittle more air pushed through it tomorrow. :bunny3:
Paul
Cool. Post more pictures of it. And video of the dyno tune tomorrow. I bet it will make a zillion horsepowers.
