maybe i should go with nawz i dunno. is there any ways to make 300 with, TB, plenum, CAI, pullies, exhaust, possibly cams, and any other stuff like thatblown97stanger said:which route do you want to go...N/A? nitrous? F/I? any of the ways are possible, 300rwhp isn't very hard with a PI motor.
96 GEETEE said:maybe i should go with nawz i dunno. is there any ways to make 300 with, TB, plenum, CAI, pullies, exhaust, possibly cams, and any other stuff like thatblown97stanger said:which route do you want to go...N/A? nitrous? F/I? any of the ways are possible, 300rwhp isn't very hard with a PI motor.
im a noob tooo lots to learn about these carsWillis_98GT said:96 GEETEE said:maybe i should go with nawz i dunno. is there any ways to make 300 with, TB, plenum, CAI, pullies, exhaust, possibly cams, and any other stuff like thatblown97stanger said:which route do you want to go...N/A? nitrous? F/I? any of the ways are possible, 300rwhp isn't very hard with a PI motor.
i imagine it will take headwork. i'm still a noob to 4.6s myself. only had my car for about a month.
ill keep that in mind do you have a link were i could buy this. and i just turned 17 so i just wanted to start with the small shit and work my way up,Red96GT said:I'm no expert either. But I do know that 2v 4.6's do not respond well to most mods without a power adder. I do know that with a little bit of heads, cams, and intake work you should be right around 300. Powerheads sells their stage II PI Swap that is "guaranteed" 110 rwhp using the Romeo heads, cams, and intake along with a valve job, and springs. It is pretty expensive at $2700 but worth it in my opinion instead of wasting time with 5 and 10 HP here and there with the basic boltons.
95PGTTech said:if you haven't already swapped in the PI motor into your GT, don't bother.
Vortec S Trim
$3130
http://www.andersonfordmotorsport.com/blowers/46-blowers.html
Easy installation, bolt on, good power, plenty of potential for more.
Vortech V-1 S-Trim Supercharger
The industry standard supercharger
* Straight cut spur gear
* Fits engines up to 680 horsepower
* Maximum airflow: 1,000 CFM *
* Maximum boost pressure: 20 PSI *
* Maximum impeller speed: 50,000 RPM
* Adiabatic efficiency: 72% **
* Available with straight or curved discharge and clockwise or counterclockwise rotation
96 GEETEE said:ill keep that in mind do you have a link were i could buy this. and i just turned 17 so i just wanted to start with the small shit and work my way up,Red96GT said:I'm no expert either. But I do know that 2v 4.6's do not respond well to most mods without a power adder. I do know that with a little bit of heads, cams, and intake work you should be right around 300. Powerheads sells their stage II PI Swap that is "guaranteed" 110 rwhp using the Romeo heads, cams, and intake along with a valve job, and springs. It is pretty expensive at $2700 but worth it in my opinion instead of wasting time with 5 and 10 HP here and there with the basic boltons.
Red96GT said:96 GEETEE said:ill keep that in mind do you have a link were i could buy this. and i just turned 17 so i just wanted to start with the small shit and work my way up,Red96GT said:I'm no expert either. But I do know that 2v 4.6's do not respond well to most mods without a power adder. I do know that with a little bit of heads, cams, and intake work you should be right around 300. Powerheads sells their stage II PI Swap that is "guaranteed" 110 rwhp using the Romeo heads, cams, and intake along with a valve job, and springs. It is pretty expensive at $2700 but worth it in my opinion instead of wasting time with 5 and 10 HP here and there with the basic boltons.
http://www.powerheads.com/headswap.html
