Blow by question which pcv to use
GThang98
Okay so since I installed my Paxton I've been having a lot of blow by and I was reading up to put two breathers on each valve cover but if I go that route how do I delete the pcv? The other way I heard is using a pcv from a svo? But shouldn't you guys think I would be better off using a 03 or 04 cobra pcv valve?
armyed
Just delete it all together...pull the whole PCV setup out and run a breather bad there or run a small line somewhere to a small breather to have that extra bit oh air flow.
