apsmith49921
- Joined
- Aug 5, 2020
- Messages
- 1,042
- Reaction score
- 890
Have you pinned the whole harness out with a multimeter? Also where did you find connectors at? I've been struggling to find them
Connectors I had gotten from a friend over a year ago and where he had gotten them from I have no idea unfortunately.Have you pinned the whole harness out with a multimeter? Also where did you find connectors at? I've been struggling to find them
Absolutely all connectors are in the exact spot, I've gone through the first harness wiring half a dozen times to confirm I've got the wiring correct before attempting to start the car then noticed that I had no spark so I made an entirely new harness last night again double checking and triple checking all positives and negatives were accurate and still same issue, ive completely given up on that conversation. I just relocated my original coil packs to the fire wall behind intake manifold and will run it that way.Odd question, but did you make sure all the pins on the actual coil connectors are in the correct spot? Power to power and signal to signal? I know signal will pass through some, but are the pins in the correct spot?
