can i?
94mustanggtfast
can i put my turbo kit on my stock 5.0 gt and run low boost until i can afford to get it tuned or do i need to wait until i can do both?
ivan12
Highly doubt you'll be able to drive it even with low boost. I'd wait
Musturd
Put it on run low boost you need bigger injectors and fuel pump I'd run one shade cooler plugs as well. And you will have to pull a bit of timing if ur fairly familiar with these cars you should be ok. I'd get it tuned right away
forcefedhatch
It'll be ok up to about 5 psi but, itd be best to run a boost referenced fpr I'd lock the timing at about 14* to be safe.. 42's a walbro 255, a descent maf,and a good tune depending on the turbo and mods will net block splitting rwhp numbers, keep it safe at around the 430-460 rwhp area though..
Sent from my iPhone
Jerry santos
