ccrm or what?
94 DropTop
Ok awhile back i noticed my cars high speed fan wasnt coming on as it should or atleast i dont think so. So i pulled the plug and the high speed wire plug looked a little melted. So i did some testing. The low speed comes on fine and i showed 14volts while the car was running. When i turn on the a/c(everything is removed from the car, dont know if this matters) i only get .08-.10volts on the plug. So i assumed the plug was burnt and wasnt getting power threw it. So i cut a little bit of the skin back and put the volt meter directly on the wire and get the same .08-.10 volts out of it. So is the ccrm bad? I checked the fuses and they were both still ok.
