CEL code
infamous209
I ran an obd 2 scanner and got two codes p1443 and p0401. What are these and what do i do to fix em thanks
duff daddy
* P0401 Insufficient EGR Flow
egr vavle or sensor could be failing or contaminated
P1443 Evaporative Emission Control System - Vacuum System - Purge Control Solenoid or Purge Control Valve.
could have a bae purge solenoid, control valve, or bad wiring to or from the part.
I
infamous209
looks like a very simple swap probably do it sat morning before goin cruisin with the new clutch and the top down. Thank you both!
