CEL
1994gt
1994gt
And the fan turns on as soon so a turn max air conditioning on.
1994gt
1994gt
I stays on while the air conditioning is on. And the hi and low turn on for about the same time I think. Maybe not exact but pretty close. I have no drivability issues with this. Runs perfect. Just this annoying light after changing the header gaskets. Only electrical I touched was unplugging the battery and removing the oxygen sensors. Didn't unplug them, just removed them from the X pipe. After that, I'm now getting these codes. And everything is connected. I verified all of that several times just in case I did miss something.
Well it sounds like the fan is working properly then.
When was the last time the engine had a tune up?
Plugs, wires, cap rotor, fuel filter, PCV vlv, clean MAF and IAT sensor.
1994gt
1994gt
All of that was done a year ago with quality components. All except the PVC valve. It had a new IAC valve cause I was having idling issues while the ac was on. Car would want to die when the ac was on. But this was all done before I did the gaskets with no issues. Didn't have a cel until I swapped out the gaskets.
Jerry santos
Staff online
