Center console is stuck!
Daryl
SoCal
Ok, did everything right: removed shifter knob; removed shifter bezel; removed the 2 7mm screws from the dash; removed all 4 screws from the armrest/storage compartment; unplugged fogs, cigarette lighter and all electrical connections underneath the console.
And I still can’t get the console out. I’ve tried every which way and angles.
1. Still feels like there’s something holding it in… maybe around the area adjacent the inboard passenger seat seat belt (female end, not the buckle)
And
3. Do I need to to remove the brake lever? If so, is it just that one dinky-ass screw?
I can angle the whole piece up and get to within about 3” to the end (or top) of the brake lever, but no further without risking snapping the whole piece in two!
Any help, pointers or tricks?
you need to yank the brake lever as hard as you can to get it up as far as possible and then you can wiggle it on/off. It is no fun.
Daryl
Daryl
SoCal
I’ll try cranking on it again, but I gave it a good shot earlier. Maybe if I get in the back seat, position myself with one foot on the back of each seat, then reach out with both hands and pull like a MoFo ?? ROFLMFAO
07GtS197
Fort Myers, Fl
Be careful not to pull the e brake up too hard. I did that in my blue 00 gt and ripped it off the floor pan. It is a pain in the ass to get out but you have to angle the rear up as high as it goes to clear. At least that’s what worked for me in the past.
Daryl
Daryl
SoCal
Any downside or risks involved in removing the nuts fore and aft to get the brake lever out of the way?
Daryl
Daryl
SoCal
GOT IT!!! But it actually came out pretty easily after those last few clicks (thx again, lwarrior) by bringing the front up and away from the dash/shift lever instead of raising the back up.
Hey, whatever works, right?!
Daryl
Daryl
SoCal
Successfully removed retaining piece, in tact, by using a solder and plastic wrench to break the plastic-welds
Daryl
Daryl
SoCal
At this point, do I line up the new rubber and retainer piece and just go tab by tab and plastic-weld staples back into it to hold in place? Or use remaining tabs, heat them back up and “mush” them back into place? I’m guessing Plan A.
cobrajeff96
Germany
Use as much original stuff as you can, makes it easier/quicker. But have plastic weld sticks on hand in case what's remaining isn't enough to hold it down.
Daryl
Daryl
SoCal
A little preemptive surgery! Some light dabs of contact cement to hold the rubber in place. Then stitch retainer over it with plastic-weld staples image.jpgimage.jpg
shovel
If you just spend 30 seconds with the biggest pliers you have you can disconnect the ebrake cables from the rear calipers and then not risk bending or tearing the cable stops under the console.
if ya thought getting if off was fun(that's what she said) wait till you try to get it back on now with the new boot on that brake :)
Daryl
Daryl
SoCal
Maybe I lucked out, but it went back into place very readily. Thankfully; you had me a bit apprehensive there, Scott! Needed an extra set of hands so used a “two-buh” to pro up the back end while I reattached all connections.
Daryl
Daryl
SoCal
After plasti-welding in the stitches and clipping the ends off, I went back with the soldering Gun and melted plastic over the stitches to help anchor them.
GTamas
Austria
Nicely done! I think this is going to be one of my winter projects.
Daryl
Daryl
SoCal
GTamas,
Next advice is what I got here from lwarrior: crank that brake lever back real good (without snapping something of course). That made all the difference in getting the console off.
Other than that, it wasn’t as bad a project as I thought it was going to be. Message me if you need pointers when you get around to doing it.
Cheers!
jamesd
