Changing emblems
GU3S GT
Im changing emblems, and am wondering what you guys use to clean off the old glue without damaging the paint, also i dont want to use a razor blade..
Thanks
ive heard of guys removing them by heating it with a blow dryer or something and then using a fishing line pulled tight to sorta of cut it away
dutch
95convgt said:
1STOF3 said:
Took my old ones off with just a hair dryer!
I'm a male what's a Hair dryer :)
I use the wind in my hair from having the windows down :)
:laughing4: But yeah, hairdryer works. I used it to get the doordings off of my probe.. used it for too long though, burnt out so I had to buy the misses a new one.. :dontknow:
x182dan said:
which emblems are glued on and which ones are bolted on?
All our emblems are glued on, no bolts, just pin holes...the fender emblems have 1 hole behind them, and the ford emblem on the back has 2 holes.
Use a hair dryer and a plastic blade and they will come right off...the excess should be easy to remove.
How big is the hole left? Big enough that it could cause rust problems? Could I get plugs small enough to fill them in?
jc95gt
the holes are about the size of a dime
i just changed my emblems last week
x182dan
ohh so you cannot remove the emblems and leave nothing there since theres gonna be a hole
BlkoutGT
MO
the proper tool would be a heat gun. But to save money, a hairdryer does the trick, just not as fast as a heat gun.
