checking valve guides
footbrake
Well first let me say hello, as this is my first question here. :wave:
Now. I am putting on a set of gt40p's on my car, I had a 3 angle
valve grind done on them. I asked the machinist if the guides were good and he hesitated ( as if to say he forgot to check )
and then said yes they were fine. Not convinced of that I pulled the springs off and I am checking them for myself.
Now ford says the specs for these heads are as follows . Valve stem to guide clearance intake (inch) (0.0010-0.0027)
Valve stem to guide clearance exhaust (inch) (0.0015-0.0032)
Now I have no way to really measure this at home so I just mounted my dial indicator on the head ,set it as close to the guide as I can ,raised the valve slightly off the seat and rocked it back and forth. I know this is not a true measurment but here is what I got. The worst intake
valve was .003 the worst exhaust was .004.
Now knowintg that fords max is (we'll round it to .003 at the guide ) and knowing that I am not moving the guide exactly side to side but I am rocking it like a teeder todder does this seem good?
Do any of you have a better shade tree ways of checking them. Like I said, the guy said they were fine, but he just didn't strike
me as the best I have ever seen , and that will be my last use of him most likely.
Any ideas?
F
footbrake
I just thought I would let you guys know.
A co-worker had the tool for checking guides and he let me borrow it. the shade tree metod I used was .001 off from actual.
