Cleaning powder coated calipers
Brian95SVT
Chesapeake, VA
Hey yall,
I am thinking about getting my brake calipers and brackets powder coated and Brandon (98four.six) said that most cleaning supplies will be to harsh on the powder coat. Are there any products out there that would be safe?
5litrarag
If its powdercoat, soap and water will be plenty. I have anniversary Cobra calipers on mine and nothing ever sticks to it that would force me to need anything more than what I use for washing the car normally.
95opal
Like stated nothing more than mild sope and water.
powder is more durable then paint I would not worry too much unless you are using an acid wheel cleaner.
Came home one day to find that my girlfriend was washing her car. She discovered the wheel cleaner I have for my truck and used it on her cavaliers painted hubcaps and then was confused as to why there was no paint left on them 5 mins later.....
98four.six
Portsmouth, Va.
Almost any powder coater will tell you to wash the PC'd item with only a mild soap and water. ANY chemical based wheel cleaner will ruin the finish on powder coat. I had the wheels done on my Speed3 twice. First time, the shop that did it said that it would be fine to use a cleaner for them. Sure enough, after the first wash, it created streaks through the finish that almost looked like runs in paint.
The second shop i took them to specifically said to NOT use any wheel cleaner to clean them. A mild soap and water is all that is needed/recommended to clean powder coated stuff. Also, do not use a scrub brush unless it is very soft. Like mentioned above, powder coat is pretty resistant to stuff sticking to it so water and soap is great at cleaning it.
det_riot
Dearborn
I clean my powdercoated wheels just with my car soap and my microfiber mitt.
EdgarR213
