Clutch fork cover problem
topless95
I just finished installing my rebuilt t-5 and everything is back together, but when I went to install the clutch fork cover, it is about an 1/2 to 1 inch from sitting flush. I did buy a new fork for the 1995 and I did compare the two (side by side) and they appeared identical, but now the cover will not go back on. The fork is seated on the ball,as the clutch fork does not wiggle back and forth, and the clutch is releasing and engaging good. Any ideas????
Paul
Yes, send me your clutch fork cover. I'd like one for my notch. :)
ryclef331
yeah...leave it off. just don't try crossing in rivers in the car, you'll be fine. They are tricky to slide on sometimes...just keep fucking iwith it it'll go on.
T
topless95
Well I think I am going to have to pull the trans out, and install the old fork. I noticed that the cable is at an angle, which appears it will eat into the cable housing.
