clutch pedal?
jareds98gt
so i went out to start my car, pushed in the clutch and heard a snap sound, the pedal then went to the floor. what could have broke???
J
jareds98gt
i looked at the pedal and the cable is still attatched to the adjuster. should i look under the shield on the tranny.
97blackgt
yeah i would see how much slack is down on the tranny itself
u can also have someone press the clutch while u crawl under the car and look
uncltrvlnmatt
Pa.
Check the tranny end. If that is still atached to the trans, diconect it and try to pull the cable out of the casing. If it is broken it should pull out. If it is in one piece you broke the clutch or fork. But that is doubtful.
J
jareds98gt
so if i did brake any one of those, would i get them from FORD?? anyone reccomend upgrading the cable?
97blackgt
get the stock non adjustable cable
ive heard of lots of problems with the adjustable ones
