Clutch problem?
Blk97GT
I had a new clutch installed about 2 weeks ago. On my way home from work my clutch pedal became very hard to push in and finally I could not move it. I pushed down hard and heard a bang and the pedal went limp until I pulled it back up and now it is stuck in place until you push hard enough to hear the bang and it goes to the floor. The cable is ok, the clutch fork seems to be ok( moves freely with the cable off0. The pedal moves freely with and without the cable attached until you pull it all the way up and then it locks in place. You can release it by hand by pushing down on that button type part on the backside of the quadrent, does my quadrent need to be replaced or could this be somehting else? I cant drive the car cause I cant shift it so this sucks. please help. Thanks
B
Blk97GT
Problem solved. The clutch fork was bent and the pivot ball was bad. Replaced both and the car shifts smooth as butter.
