coast high crate motor what ya think?
turbo80lxcoupe
ok so since i havent figured out exactly what im gonn do this tax season,i thought i would through this out there and see what you guys think.
heres the link to a motor that is about what i was looking at building.
http://www.coasthigh.com/ProductDetails.asp?ProductCode=11884%2DPS%2DF4%2E6L%2DLB&Show=TechSpecs
i was thinking of going n/a.i would prefer it compared to a blower with the millage.the set up i was thinking of has the same short block,possibly the new trick flow heads or some stage 3 fox lake heads,with anderson n-51 cams,with a compression ratio of 11.5:1.and a port matched pi intake or possibly the trick flow unit.i want 375 + to the ground.and yes i know its gonna cost a pretty pennie to do,but i think this motor setup should get me there.also am planning on using n2o.thats the other reason for forged and high comp.so what do you guys think?
thanks joe
GDTrumbo
Nashville, TN
thanks joe
Nice set-up. Too much compression for the street though. Anything over 10:1 is gonna be hard to deal with.
GT
T
turbo80lxcoupe
not too worried abou the comp i have a very good tunner close by,also was gonna buy a 55 gal drum of 100 unlead and mix with 92 oct should be fine,my last fox body when n/a was 10.5:1 wasint too much of a problem,my concern is that the heads are from patriot been hearing bad things about there modular heads
T
turbo80lxcoupe
what do you guys think that motor would make power wise?do you think it would put me close to my goal?
thanks joe
Jrgunn5150
Off the shelf part's ain't gonna make more N/A power than anyone ever has with a 2v.
T
turbo80lxcoupe
im not expecting to make more power than any one has,granted i dont know what the most n/a power some one has made with a 2 valve.i would guess around 500hp at the flywheel isint comon but im sure it has been done a few times.i guess i should say i want around 375 rwhp not 375+ rwhp.i want to take out my buddies 2001 ls1 catfish.his car is making 350hp and 360tourqe,i now i wont make more tourqe due to the displacement.but as long as i beat him by a fender i will be happy.and i want to try doing that n/a,and the n2o would be for when he gets around to h/c/i
thanks joe
T
turbo80lxcoupe
well now after reading the article about the 435 hp 2v i think im gonna have to wait until trickflows new heads come out or get a set from livernois.the redisigned combustion chamber sounds like it is playing a big role.
