Engine mount question, engine sits high
RAU03MACH
NEW MEXICO
here is another sample of mine without super charger about the same20190823_135153.jpg
even this one on the stand looks the same distance or placement close to alternator
i don't think you're missing anything
may be the water tank is different
1BadSVT
1BadSVT
to me it looks like the position is the same View attachment 49151
here is another sample of mine without super charger about the sameView attachment 49152
No offense but I'm not following. I was just mentioning the water outlet tube in relation to the car body. Let me make a side by side to show the delta.
shurur
If lowering the engine is what you want to achieve, you could always go solid mounts. Having installed a 5.4l, its tall. Installing the solid mount gained me roughly an inch of clearance at the hood. Alot of folks dont like the solid mount engine vibrations resonating the car, but I dont mind it.
I Had the energy motor mounts melt on me.
Motor still clears the frame....
I have solid mounts and OEM DEI that I could install next.
Do the solids really introduce all that much vibration? I just don't mean to do motor mounts three times...
Then there is the issue of the original heat shields which I threw out...
1BadSVT
1BadSVT
i cant see where there is any true difference
I still owe y'all photos from underneath. I've been busy and traveling so hope to get that uploaded Sunday. I went ahead and ordered the solid Maximum Motorsports mounts. No tracking yet but hope they arrive soon.
Snorky
Hmmm... do you really gain an Inch of clearance??? And no goofy K spacers?
RAU03MACH
NEW MEXICO
I will take a few pics under the car tomorrow its on my lift now so i will get them and then you can compare
also you may want to check make sure you don't have the 94-95 k member
not to sure about the difference from 94-to 96 the OEM K could be the same
1BadSVT
1BadSVT
Here are the Maximum Motorsports mount photos. They got me about 1/4" more. I cut the throttle cable bracket on the KB SC a bit more and had to install the OEM intake. The JLT was also hitting the stock hood. I wonder if the worn out mounts were there by design or the original owner just installed the KB with it that way.
RAU03MACH
NEW MEXICO
So your motor mounts are a bit different
Mine have the rubber pad witch you would think it would be thicker and raise it a little
I dont see a rubber pad on yours is it a solid mount
Musturd
If you didn’t have a stock k member with coil springs I’d say space the k member down half a 1/2”
1BadSVT
1BadSVT
I was talking to a friend who has a 98 Cobra and he mentioned he has the H&R super sport springs. I've been running lots of numbers on different wheel sets and tire sizes with their overall diameters and sidewall trying to find the look I'm going for. I will have to get the springs once I get the car sorted.
I've settled on 17x9 square to start and I think I'm going to go with 275 40s with a 200 to 320 treadwear. Haven't settled on a tire but I like the NT 05 nittos, the falkens, and there's nothing like a set of Michelin pilot sports. The H&R Springs will lower the car a little more than what I have to get the look I'm going for.
badass98svt
275 40 is a short tire.
I run H&R SS springs out back. They ride nice. I used to have them on all 4 corners until I did the MM coilovers up front.
Mikehonco69
