Cobra Head&Cam help
Lebedin8654
How can you tell if a Cobra cam is a real Cobra cam and its not a GT cam? Are they the same?
And
What kind of lift are GT40 head capable of handling with stock springs? My valve springs have the little helper spring on the inside is that stock for a Gt40 head?
Thanks for Any Help!!!
94-5.0GT
for the cam you would have to compare the numbers on the front part, i dont know what numbers does the cobra has or the gt. what are you planning of doing? i would go with an aftermarket cam
stock springs on a gt40 can handle up to .500" lift
topless95
the cobra cam has less lift than the GT cam, so in other words go with a new cam
stang94X
cobra cam is just a little higher lift but they did come stock with 1.7 rockers which makes it a higher valve lift and it has a wee bit lower duration
Paul
Ah, you're probably right. I'd need to search for the lobe lift on a Cobra cam.
LAFENATU
I have a book full of tons of camshaft info..stock cam has slightly more duration..
Stock GT cam - 210/[email protected] .444/.444 115 LSA
Stock 1993 - 1995 SVT Cobra Camshaft - 209/209 @.050 .451/.451 118 LSA
5.0L Thunderbird - 183/191 @.050 .381/.395 107.5 LSA
L
Lebedin8654
i am upgrading my cam and a guy i wants a real cobra cam and i am 99 percent sure that this is one but it says GT between one of the lobes but i was told it was a Stock 95 cobra motor!!!
stang94X
if youre just going from a stock gt to a cobra cam i wouldnt waste the time with that, its better to have a gt cam and upgrade to 1.72 rockers than to have a cobra cam, or get a good off the shelf cam and rockers and it'll be better
I'm pretty sure Paul is right, if my memory serves the Cobra cam has more lift even before the 1.7 rockers. Don't feel like checking my service manual to confirm it right now though...
LAFENATU
I posted all the cam specs a few posts up homey.. :)
Hoseitdown
i thought that the cobras had a smaller lift cam, thats why they put 1.7 rockers on it....
no, but I think it has less intake duration and more exhaust duration. Someone correct me if i'm wrong.
LAFENATU
