Cobra Pics?
voidfinger
hey guys, do you have any cobra engine bay pics from the top strait down?? I'm looking for the front accessories and between the radiator and front of the engine.... From top and bottom. I'm trying to figure out what some of the stuff is.... there is a black box with lines running off it right beside the air box, then there is a thing attached right under the drivers side coil pack that looks like a fuel filter.... i have no clue what it is and i'm curious about the radiator hose thing.... there is like 3 that run into a metal "thing" at the bottom.... I have no clue what that is either.... any help guys.
reivaxtorres
that metal box besides the air box, are you sure thats not the ABS system? last i checked, that was the location of the ABS on our cars. should be like 5 or 6 metal lines going in/out of it, right?
for the radiator hose thingy, i got no idea.
V
voidfinger
I don't have the box..... I might not have abs.... doesn't shake when i lock them down.
thanks... I wonder if i can convert to the abs...
Anyone else have pics or ideas..
reivaxtorres
19mustang95
the things below the coil packs are part of the SAI (air injection) system, they are emission crap and are tapped into the headers and a/c system. they are waste of space just like the EGR so i am trashing it all(actually ended up leaving it on the motor when i traded someone). there is also the pump for the SAI in the passenger side fender.
V
voidfinger
So i don't need that then??? is there something on the cobra wiring harness that hooks to it??? will it throw an error code? can it be deleted in the programming so that it won't throw the code... ? If i don't have to have it then great. I don't have the antilock brakes either....
Now one of the photo's has the pic of the bottom thing.... It hooks to the hose coming from the cross over and the hose from the oil filter locations..... what is that thing that joins them..... where can i get one..... ??? Is there anything else diffent between the gt and cobra that i haven't thought about .... I'm piecing together a cobra motor... i'll have the t45 and i got the complete cobra harness and the cobra computer. Thanks guys.
19mustang95
there are one vacuum line to both that you must cap off. or if you delete the EGR as well, i think you can take off the whole vacuum line part that connects those few, not sure.
V
voidfinger
... i haven't even thought about vacuum lines.... can i reuse the gt lines??? I'm deleting the egr... and doing the pcv strainer to help with the crud problem. So.... man this is complicated.
