Cobra
96laseredcobra
96laseredcobra
Farmington MO
So with new plugs and newer wires and msd coil packs now getting a new p0304 misfire code anything to look for
sent from somewhere,while in my cobra.
Tillerman77
Willamette Valley, Oregon
Same code popped up on my 97 Cobra. After going through plugs, wires, coil packs, checking injectors & wiring, it turns out to be due to partial compression loss on cylinder 4's valves (seat, carbon, spring, etc.) My car is sitting until next March/April to check out the head/valves. I had a shop do the diagnosis. The static compression was fine on all cylinders, but a "timed" idle compression test showed #4 built compression more slowly than the neighboring cylinders. See example 3 in the link.
96laseredcobra
96laseredcobra
Farmington MO
Same code popped up on my 97 Cobra. After going through plugs, wires, coil packs, checking injectors & wiring, it turns out to be due to partial compression loss on cylinder 4's valves (seat, carbon, spring, etc.) My car is sitting until next March/April to check out the head/valves. I had a shop due the diagnosis. The static compression was fine on all cylinders, but a "timed" idle compression test showed #4 built compression more slowly than the neighboring cylinders. See example 3 in the link.
When I got it it was 307 an that went away after all new parts. Then I'm getting 300 and 304
96laseredcobra
96laseredcobra
Farmington MO
fog lights mod
Burninriverdiver
The fog light mod is great, I always hated that they didn't come on without headlights on too. Gotta love the thorough step by step write ups on this site. Your cobra is looking good man
96laseredcobra
96laseredcobra
Farmington MO
Thanks , I actually just watched a 3 min video on YouTube. Dude had it done in under that so I was like what the hell why not try it. No cutting just pin swap. Had er at local Jack in the box and and competition orange v6 pulled in next to er. Guy and his gal come inside, he asked if she's mine so I'm like yes sir with a smile cause I saw him staring er down while holding pass door so his gal didn't accidently hit my ride. He said my ride was madly beautiful lol. Tried selling me a set of 22s black with red stripe. He had about 10k worth of gold in his mouth. Lol ,really nice guy though.
96laseredcobra
96laseredcobra
Farmington MO
Dropped er off for longtubes and clutch install.. vid coming soon of exhaust sound. Then it's time for Moar low!
96laseredcobra
96laseredcobra
Farmington MO
So I got er back no work done from that shop. So installed new headlights and corners. Now at a shop inside and in lift being treated nicely.
