Cobra
96laseredcobra
96laseredcobra
Farmington MO
Looks like bad plugs was an issue. New copper core plugs to match the new msd plug wires today. So far no mifires and shes back alive and peppy. Need both upstream O2s replaced now.oh and i caused the code by removing the pcv valve with it running lol
96laseredcobra
96laseredcobra
Farmington MO
Misfires gone . But now the dreaded coolant leak at tstat housing. New oring and tstat, and new resivoir cap. The new cap has helped a little thinking the other new one wasnt venting. Found a new housing but its only half ?
96laseredcobra
96laseredcobra
Farmington MO
Update is , located the coolant bypass hose, housing and top rad hose. Now just waiting for them to arrive. This will make the cooling system all new. If it leaks ima set it on fire!
evilcw311
Most Evil Member!
Louisville, KY
Before you set it on fire put a real motor in it and you won’t have all these problems!!!!! ;-)
96laseredcobra
96laseredcobra
Farmington MO
Here and in route to fix the coolant leak. Thanks to a svt buddy goes by moose. Out in cali.
evilcw311
Most Evil Member!
Louisville, KY
Damn!!! I was hoping for the 460 swap!!! [emoji38]
Glad you got it fixed dude
96laseredcobra
96laseredcobra
Farmington MO
I hate leaks, however i like leaks over disappearing coolant. Glad it worked out.
Me too and yeah when it just goes who knows where isnt fun. Ir when ypu check coolant and oil and the coolant resivoir looks like a milkshake.
