Drentz
Dear new Friends,
I just did a KOEO and a KOER test, Also a Cylinder balance test.
I'm going to list the codes I got and I want you fellas (and fellettes?) to tell me what to do! But first i will tell you what the car is doing, First off it is having a hell of a time starting, it backfires, the idle is low, i can only go like 20 in first (after 3500 rpm it stutters and jumps). I'm sure it does other stuff i'm forgetting at the moment.
about car: 1994 Mustang Cobra, 121,7XX miles, New MSD cap and rotor, New water pump as well as upper and lower hose, new battery, and new Idle air control valve! also new vacuum line going to intake, as well as new PCV.
my stepdads stepdad bought it new in "94" (i.e. 93) then when I was ten he gave it to my stepdad, and now my stepdad gave it to me. Oh how happy I was. Long story short, I love this car more than anything and I need to help it get better.
KOEO:
113 - ACT Sensor Circuit Above Maximum Voltage of 4.6 volts (O), ACT circuit has intermittently failed above the maximum of 4.6 volts (CM)
176 - o2 Sensor circuit indicates system lean (left side)
KOER:
116 - ECT out of self test range 0.3 to 3.7 volts
Cylinder comp test:
4 (so my 4th cylinder has bad compression.)
Please and thank you!
KOEO:
KOER:
Cylinder comp test:
