convert to a fox setup?
itsblue95
Louisville Kentucky
what all is needed to convert to a fox setup? my buddy might have found me a blower for $1000 but its from a foxbody. thanks in advance
Venomous96Cobra
Central Florida
if you are doing a complete swap you will also need the upper intake, throttle body, accel+cruise cables, and some wiring skills since you will have to rewire the aic valve, tps, etc...
IceMan
Too much work to convert for a blower... You need the upper intake, pulleys, front cover, throttle cables, brackets, water pump. Not worth it. I got a Procharger P600b for a 94-95, I might be selling for $1200, front mount intercooled kit with everything to put on and drive and install instructions, 8, 14 and 17 PSI pulleys and an FMU (if you use stock injectors). I was keeping it for my 94 GT but I'm thinking about selling it.
itsblue95
itsblue95
Louisville Kentucky
Yea that's to much work for it. I'll keep that in mind that your selling yours iceman. I called Paxton and they don't sell the bracket anymore.
