Could anyone with 1" bolt on spacers do me a favor?
sleepn_sn95
Indy
My xxrs have a small pocket on the backside of them but I need to know how much the stock studs stick past the face of a 1" spacer. I think there will be enough clearance but I just want to make sure before I buy anything. If someone could measure how far the studs extrude from the surface of the spacer that would be awesome
I had to cut the studs about 1/2".
Addermk2
Get 3" moroso studs and take the Chinese hardware off them.
FivepointSlow
Enfield, CT, USA
It's dark here right now. But I have 1" hub centric spacers, stock studs.
Since these pictures I've replaced the brakes and studs but they're the same stock length studs and still work. You can sort of see the little pocket at the bottom of this picture on the back of my 03 cobra reps.
and this is the only not straight on angle I have of the spacers not sure if it helps you tell how much they stick out..
They don't stick out more than 1/4" probably less. I can't out the nuts on the spacers without a socket. I can maybe get a thread or 2 started by hand but the studs are really set back in there.
Here's them with my new brakes..
Still a bad angle but you can tell they don't stick out much.
sleepn_sn95
sleepn_sn95
Indy
Thanks [MENTION=18995]FivepointSlow[/MENTION] those help a lot
Your pockets look about the same as mine so Im sure they will work
FivepointSlow
Enfield, CT, USA
[MENTION=10867]sleepn_sn95[/MENTION] I'm swapping the rest of my lug nuts later today... (Bought enough for 1 wheel last month and after likin them got the other 3 wheels worth) Want me to grab some pictures and measurements for you while I'm out there? Just as reassurance. Lol
chris91
Cincinnati, OH
My spacers wouldnt work with my XXR's. Would have needed to cut the studs and I didnt want to do that so Im dealing with the look for now. Eventually Ill get around to putting longer studs in it.
sleepn_sn95
sleepn_sn95
Indy
sleepn_sn95 I'm swapping the rest of my lug nuts later today... (Bought enough for 1 wheel last month and after likin them got the other 3 wheels worth) Want me to grab some pictures and measurements for you while I'm out there? Just as reassurance. Lol
Yeah if you dont mind that would be great
What size spacers were you running and did the xxrs have the little cutouts in them?
FivepointSlow
Enfield, CT, USA
My pockets are WAY bigger than I thought. But studs are the same.
Regular lug nut for reference
My 60mm lug for reference
Pockets on my rims
Fat finger for reference.
sleepn_sn95
sleepn_sn95
Indy
Im going to have to pull my wheels to see if it will work
sleepn_sn95
sleepn_sn95
Indy
Just pulled a rear wheel and the little cutouts are 0.50" deep. Studs are 1.25 so with a 1" spacer it should work perfectly. Just sent some money over to [MENTION=18995]FivepointSlow[/MENTION]'s buddy for his 1" spacers so they should be here and on soon
chris91
Cincinnati, OH
That's what I plan on doing eventually. You have to pull the axles to do it though right? Can't f**kin stand gear oil... LoL
rz5.0
Great state of TEXAS
That's a lot of stress on those studs. . Not something I would recommend. That's just me tho. .
Enviado usando mi SHP-L710 usando TapaTalk
Addermk2
Rodrigo. ive put the car down the track with a 1.6 60' on those studs. i am more likely to sheer an axle, than break those studs.
rz5.0
Your one of the few person here that I would actually ask and trust with any advise on this forum. . But i still think it's a bad idea on a DAILY driver. . More stress out on the street. . Most cars on here are daily driven. .
FivepointSlow
Enfield, CT, USA
I'd think about replacing your studs for sure. I'm totally comfortable with my spacers because I just swapped out my studs for brand new ones. Then again the ones on my car where original and my car sat for 13 years so they where weak as hell. Lol
Glad you and my friend made a deal!
Pete@FTR
Preferred Vendor
Rocklin, CA
You shouldn't be using bolt on spacers.. strongest and safest option is normal spacers and arp extended studs
EdgarR213
