couple issues
svt slobra
ohio like everyone else
ok guys,
today i got a trick flow intake plenium and throttle body. after installing it on my 2000 gt, it seems to have an idle hang issue and a stalling issue at stop lights. i cleaned the egr,replaced the vac lines and made sure everything was sealed. drove the car around the block and its still acting up. it also runs rich i believe(little bit of a backfire/pop on shifts)
this set up worked flawlessly on my black gt, so i really doubt its the plenium or TB....but my car did run good before i installed these
could an o2 sensor cause this? i had a cel turn on for a min and then go out the other day. ran the stored code and it came back as bank 1 sensor 1 malfunction.
and issue number 2.......
for some reason i have no cluster or heater control lights with the dimmer switch......all controls work great and guages all work.....any ideas on that?
svt slobra
svt slobra
Ok guys think I just figured it out.......re adjusted the throttle plate screw and then let the car idle for about 15 mins to let the pcm find idle air fuel trim.....seems to be doing good now....gonna take it for a ride and see what happens
Sent from my Kindle Fire using Tapatalk 2
