couple o ?
drftrmike
OK my first is can some one point me in the direction to find a diagram or how to for removing the power mirrors on a mach 460 equipped vehicle
second i have a 03 gt rear end now i know it will fit in my 97 but i have one inch spacers on the 97 rear end will they put the 9 inch wide wheels outside the fender if i install them on the 03
second is I'm switching from the automatic to a 5 speed i ordered the swap kit from amp performance has any one done this any thing i should look out for any problems any help will be appreciated
thanks
94-427
To remove mirrows pull cover off of front mach 460 [speakers grill cover] ther will be a screw hiden under cover,once speaker out of way U can get to the three nuts that hold mirror on
Ther rear end will bolt right in and U can lose your spacers, 99 up rear axle 1.5 inces wider than the 98 down, a 17x10.5 wheel will fit undeer wheel well [yea your 9 inc wide wheel will fit]
the trans swap is strate forward change, if U have everything, comp is diferant along with wiring to transmission [make shure to get all bolts flywheel bolts longer bell housing bolts longer so get all bolts and faseners
joekd
Ct
Keep in mind you may still have to pull off the door panel to unplug the mirrors (on both of my mustangs I had to)
