Cutting springs?
Chump
TX
How do I do it? How much should I cut? An could I do this whe I change my pads and rotors?
duff daddy
With a cut off wheel
As much as you want, say a coil or 1.5 coils (thats alot)
you could if you wanted.
Chump
Chump
TX
Is it safe?
And yeah to not only be cool but I wanna get rid of the 4x4 look.
duff daddy
Its safe if you cut the rears, and use a wheel. The proper way is to replace them. I cut mine due to the drag race effect and different ride height effects 60'. Good luck.
Chump
Chump
TX
So I should only cut the rear?
Is there a write up somewhere?
robb15033
Northern Va.
I want to know too because I had the idea of cutting 1/2 or 3/4 of a spring off of my Ford Racing "B" springs before I put them on. Also putting on new shocks/struts, MM Caster Camber Plates, X2 Balljoints, and a Bumpsteer Kit.
I want it slightly lower than what I've seen B springs produce.
Do it?? Do NOT Do It??
Addermk2
cutting springs changes the springs rate properties. It's not the right thing to do, but honestly are any of my warnings really going to stop you?
That being said, alot of very successful drag race teams recommend cutting 1 coil off the stock rear springs, as it drops the car in the rear, stiffens up the spring, and aids in getting your rear suspension geometry in a favorable position.
