diffrent diameter
RED guy
hi guys
currently my exhaust set up 2.5" O/R X pipe & two chambers mufflers,i found a cheap magnaflow race mufflers (used) but one of them 3.5" or 3" not sure, if i weld them on my 2.5" system one larger than the other does it hurt on performance or engine pressure???
glittle75
na, just get reducers and such and weld them up. its after your midpipe so it wont mess up the pulses. may sound a little wierd though.
joekd
Ct
Run an open H pipe for a bit, if you can stand that then the performance with the race mufflers will be the same ofr better
joekd
Ct
You will, but only low end. It will also gain power in the higher RPMs
R
RED guy
but i dont wana change the exhaust so no body sure if one larger muffler well effect or hurt something?
96GTPlanB
Staff online
