Dome light override?
94Pro-5.0
Little Elm, TX
has anyone done or does anyone know how to make our cars have a dome override, to where you can have the dome light off even with the door open? my truck has it, and i want my mustang to have it too
Remove bulb?
Just curious, why would you want that? My 67 doesnt have an interior light and its quite obnoxious fumbling around at night when I get home.
but you want to be able to turn it on manually?
only think i can think of is modify the sensor on the doors.?
94Pro-5.0
94Pro-5.0
Little Elm, TX
there are times when i don't want to be seen getting in and out of my car :icon_rr: so i want to be able to open my door without the light coming on, whithout removing the bulb. most newer vehicles have a dome override button.
i was hoping someone knew of a simple mod, kinda like our little fog light wiring mod
Win
Kennesaw, Ga
well even if you aren't seen getting in or out there going to hear you pulling away or coming in
ProKiller
PA
your car is red, its not that inconspicuous...
the only thing i can think of would be to put a switch inline of the wires. i don't know where they are fished down through but you have 4 to choose from. shouldn't be too hard as it will be the only set that far up. use a volt meter to find out which one goes hot when you open the door.
