Dynomax or Flowmaster?
Which should I buy?
  • Total voters
GTamas
Austria
What do you think, which one is quieter at idle and cruise speed? Which one should I get for my stock 94 convertible cruiser?
Dynomax Ultraflow, Dynomax Super Turbo or Flowmaster 50 DeltaFlow?
I am not concerned about performance. It's more important to have less drone and not be too loud/aggressive.
my side exhaust is dynomaster and I am happy with the sounds with cats on the car. It was a little louder than I wanted with the off-road pipe on it.
badass98svt
I run Dynomax Ultraflow on my turbo Cobra. Best way to describe it is sedated at idle and cruising, but it has a real bark to it when you get on it. It's honestly my favorite exhaust setup I've ever had on any mustang.
Turbo cars have quieter exhaust, so your mileage may vary.
lwarrior1016
Mr. Secondary Timing Chain
Staff member
South Mississippi
I don’t know how it would compare to stock volume, but I really like hooker max flow mufflers.
They’ve got a really quiet idle and no drone, noticeable note at wide open throttle
GTamas
GTamas
Austria
Got the mufflers installed today at a shop near me. Not a clean job, but for now it works and I'm gonna let it correctly aligned during the winter.
But more importantly, they sound very good! :)
I was surprised, volume-wise it is very close to the stock mufflers. The tone is also similar, a bit more throaty I think. Cruising there is no drone and volume is maybe a tad higher than the stock was, which is exactly what I was looking for.
I only had a chance to do a short WOT run in 1st gear, but it sounds great. Loud but not too much. I like it. Thanks for everyone for the recommendation! :)
I read somewhere that the volume might change over time when the packing deteriorates/settles some. Is it something noticeable?
GTamas
GTamas
Austria
I'm not satisfied with the way they installed the mufflers, but I knew in advance they are not an exhaust specialist and don't have pipe bending equipment. Especially the driver's side muffler is not lined nicely, sacrificing some ground clearance, because the used the stock pipe segment which comes after the H-pipe connection. I will bring it to a specialist during the winter to properly install it with new pipes coming between the H-pipe and the mufflers.
badass98svt
Glad you like the sound. Yeah they should break in a bit. Nothing too drastic though.
gotcha. I found some round stock at the local hardware store that was the right size to make mine out of but if I couldn't then allthread is something I would not think about, but might use if I did. Although now that I think about it as hard as it was to get them off the roundstock hangers last time if it was allthread I might have considered cutting them out. I was surprised how hard it was to get them to slide out.
Mustang5L5
They sell hangers on Amazon. Clamp on style or weld on.
When I did my exhaust I used similar hangers but in Stainless instead, and just welded them on.
As an Amazon Associate we earn from qualifying purchases.
