easy no start saftey?
thugstang
FL
looking for the best way to maybe shut off my fuel pump or disable starter with out going through a lot of effort or buying anything at all like a fuel pump shut off switch. seen a few people driving slow while I work on car, been car thefts and break ins in my area.
It might be easier to disconnect the inertia switch in the trunk. There is a harness that clips onto it and if you just disconnect it from the switch it will not let the pump see power no matter what. But if you can come up with $15-20 and a coupl of hours to install it you can make a neat/easy starter kill switch
T
thugstang
FL
Thank you I wasn't sure if disconnect would leave it on or off. That fuse was in there good so I would have to use pliers, the inertia switch is simple disconnect so much better.
