EGR Delete Plates
ZFan88
In the middle of my turbo build and thought I could easily find these like I can for fbodys....apparently not lol. Does anyone know where I can find these?? I'm talking about on the back of each head, and the intake one.
94 DropTop
You could just use bolts. But i think it was trick flow that makes them.
Untame-d
UPRproducts sells the intake EGR delete. I got mine from there.
ivan12
The plate is easy to find, it's the same thing as the 351w fuel block off plate
Z
ZFan88
What have you used for the back of the heads? I imagine I could just plug them. Mine are still on the car...anyone know what size they are so I don't have to buy 20? lol
gregbar
On the intake its a EGR delete plate, I have found these on Ebay from cjrpony. They have three styles to choose from 87- 93, 94-95 and 4.6. They are $5 and made of thick steel and laser cut. UPR also has the plates but they are thinner. The hole in the head I call "thermactor plugs", you can get these on Ebay from inmotionpsarts for $9.50. You can also cut the tube that runs across the back of the heads connecting these two holes flip it around and bolt it back. I used the plugs.
Addermk2
Allfordmustang.com is wrong in that PDF file.
the thermactor holes in the back of the heads are 5/8-11 And you need bolts that are no longer than 1" so you dont bottom out on the inside of the castings, which can crack the heads.
Like Adder said, I used bolts that I cut down to 3/4" long since the shortest they sold them was 2" or something. If i had known how easy it was to find the plugs though I would have just done that.
95-stang
I got the thermactor plugs from CJ Ponyparts and Wazee [on e-bay] for the egr block off plate and the cap for the egr on the exhaust manifold.
Z
ZFan88
I tried both the 5/8 and 9/16 today with no luck. I imagine a 1/2" will work, so I'll try that tomorrow. Should have picked them up while I was there..
95-stang, how do those thermactor plugs go in? They look weird
95-stang
They just screw in using a large flat bladed screwdriver [i put a bit of exhaust paste on them to seal] then screw them home flush and then used a centre punch to stake them in just to be extra sure. :)
Z
ZFan88
I actually ended up cleaning out the whole with some carb cleaner and the 9/16" went in perfect. One less thing to worry about
Addermk2
they are the wrong size... clean the threads out some more, and put a fucking 5/8" there
Im so sick of al these noobs thinking that I have my fucking head up my ass when I put these bolt dimensions out.
The heads take a 5/8"-11 thread pitch... nothing more, nothing less....
Paul
ZFan88 said:
5/8" isn't close to fitting. Quit talking SH*T punk
Actually, 5/8-11 is, in fact, the correct size. Be nice (and that includes you Adder) or you'll both get a vacation.
