Eibach Rear Sway Bar
97ponygt
Okay so what’s the secret to installing this thing? As anyone bought one and installed it using the supplied hardware? I really don’t feel like there’s enough room to get a wrench on the nut supplied with the bolt and the extruding u bolts are not wide enough as the eibach sway bar is much thicker than the stock
97ponygt
So the trick is to get a person to help. It was pretty hard to try and hold one end up to get it to align correctly in the hole since the upgrade sway bar doesn't use the factory j nuts. I really recommend having someone help with this.
