Ok, so I have had a problem with my 94' Cobra recently. If I am cruising on the freeway with a consistent throttle position, the car will cut in and out (like the fuel pump cuts in and out) every 5 or so seconds, if I'm going up and down with throttle its fine. After the other night, I stated it up, ran it for 2 min, then shut it off. After that the fuel pump would not turn on. The motor would just crank, and not start. Finally after looking at all the fuses, wires etc.. and trying the ignition to see if it would prime... nothing. the only way for me to get it on is if I unplug the 4 wire harness behind the gas tank and plug it back in. Its almost like I have to "reset" the ccu behind the radiator, or the fuel pump relay for it to work. Any ideas??? Is my pump going out? its fairly new.... :BangHead:
