engine tick help
96gt4.6
96gt4.6
UT
after hearing the second video I would say its about the same
just found that if I unplug the cylinder 2 coil the tick completely goes away at idle but if you rev it up un plugged then just as it about gets to idle it ticks for a second and goes away at normal idle rpm
RAU03MACH
NEW MEXICO
when i put that engine together
the noise was way worse noisy
i could drive the hell out of it put it through testing nothing so far has changed maybe a little less noise
but it runs great, and power is good
that was almost 3 years ago use it for work once and awhile or car shows meets greets
96gt4.6
96gt4.6
UT
I keep debating just running it. I also did a manual transmission swap and haven’t had much luck finding a stock tune to upload for the manual and need it to pass emissions
Terrorist 5.0
this is how it sounds now
slight tick
about like that
Videos never give the best sound, but doesn’t sound like an exhaust leak to me. Doesn’t hurt to check though, hope it is, because exhaust is easier than valve train :)
The stage 8 locking fasteners were a bit of a pain to fit on my headers, but so was the time before I didn't use them and it seemed like there was ALWAYS one bolt that was working it way out and making a leak.
96gt4.6
96gt4.6
UT
pulled the motor and put an explorer motor in and while out found a bad lifter on cylinder 2. will be going into my kids car in the next couple weeks so we will see if that was the noise
