Engine vibrations when its given gas.
94RedGt
Hialeah, Florida
Hey guys ever since i got my car i have always had this weird vibrations when ever i drive the car hard, as in WOT , pass 2000 rpm and u can feel the vibrations coming all the way to the shifter , i have looked at the engine while its running and have noticed that my harmonic balancer wobbles while the engine is running, when looking at it from the side u can see the flat face of the balancer wobble pretty bad and i have not touched it cuz my brother told me its suppost to be like that but i dont think a thing like a balancer is suppost to rotate that way, i know the back part of the balancer is not flat but the front is and it does not rotate flush when the engine is running.
Under hard throttle u can actually hear the engine vibrate and its kind of scare like its about to fucking explode, i got a lot of vibrations on the shifter but its from the transmission that its about to go its going to get rebuild in a month.
Should i replace my balancer if its wobbling ? Also i had the tranny out of the car once to change a bad rear main seal at my friends shop and we did not mark the position of the driveshaft when we took it out , ever since that day i get a strange vibration also under hard throttle . Can the driveshaft also be causing problems ? I get no vibrations at all when cruising at 70mph so i dont think my driveshaft or anything down there is out of balance or it would vibrate horribly all the time.
Stang331
KY
Crawl under the car and check balancers, to see if the rubber is coming out. Does it do it with the car in neutral or driving?
Addermk2
stop driving the car and replace the balancer... your brother is a moron
94RedGt
Hialeah, Florida
The engine does vibrate when in neutral also and im sure its nothing wrong internally like a rod going cuz it makes no funny noises , it revs with no problem it just feels like its going to explode lol. And yes i told me brother hes a moron plenty of times :D . Is an autozone or advance autoparts balancer ok ?
g36 monkey
Orlando, Fl
Make sure it isn't crank walk. What looks like a wobble could be your crank moving in and out, which could mean your thrust bearing is toast.
hoping its just the balancer though
Musturd
Lol this is so common on these cars. Had a customer come in yesterday to get his mid pipe tightened and I saw the rubber coming out , I told him he needed a new one he drove it home only for it to get hella bad like I said then he paid me extra to do it at his house Cus it was getting really bad.. Kid scored a power bond for 75 bucks new
94RedGt
Hialeah, Florida
It is not crankwalk, i can see the front part of the balancer wobble while the pulley in front of it is nice and flush, plus the crank does not move when pressing the clutch.
Musturd
Yea just buy a new balancer and replace it doesn't take long
