lutter94
Well as for the KOER Test, I haven't successfully ran one for awhile, as this always pops up.
Unable to retrieve Cylinder ID or DTCs perfom KOER test until DTC 11 or 111
And as for the KOEO Test, see the following.
DTC:172 HEGO (HO2S) seonsor fault/lean
DTC:556 Fuel pump relay primary circuit fault
DTC:332 Insufficient EGR flow detected
I'm guessing the EGR is plugged up, thinking about tossing it anyways... But as for the other 2, could they be related? The fuel pump primes just like it always has.
Problems I've noticed.....Sometimes its hard to start, kinda like its missing, will sort of run below 500 rpm's and struggle a little to get up to idle. Once its at 1000 or higher it sounds fine. Sometimes if I put it to the wood, it stumbles and falls on its face, like it wants to go faster but keeps surging. I just replaced the fuel filter, it'd been awhile figured it needed it. New IAC this summer, and cleaned the throttle body. Prob need to clean the MAF again. I did the whole seafoam treatment in May if that has any consolation.....
