Delete
95opal
All dashs means the PCM isnt communicating with the cluster or any one of the CAN BUS items in the car. I would assume bad PCM or cluster.
dutch
dutch
Delete
cobrajeff96
Germany
I'm more of a 1st gen SN95 guy so I'm not too sure about New Edge things. But have you looked at the MAF yet?
07GtS197
Fort Myers, Fl
Still, with the dashes showing up on the dash that’s a classic sign of ccrm issues. The relay for the fuel pump could have a cracked solder joint causing intermittent fueling issues.
cobrajeff96
Germany
Could be that the relay is just so worn that the inner armature is making poor contact and arcing inside. I'm pretty sure the relays inside are not solid state variety. It's easy to swap in a known good CCRM. That's like a 30m job.
07GtS197
Fort Myers, Fl
I’m pretty sure all automotive relays are solid state. The ccrm uses a four pin relay but I’m pretty sure it’s pretty much the same thing as a regular automotive relay otherwise. It’s been a while since I fixed a ccrm.
cobrajeff96
Germany
Not very common back then, actually. Certain components were, most not (attached).
07GtS197
Fort Myers, Fl
I was under the impression a solid state relay was the regular electro mechanical automotive relay but even google has it wrong. I see it now.
dutch
dutch
Delete
dutch
dutch
Delete
cobrajeff96
Germany
SS relays have no moving parts, they're pretty much just transistor logic. They last a really long time.
96GTPlanB
