Evolution of a 97 Cobra
Gallows
Gallows
Summerside, PE, Canada
I got it back together 1-1/2 weeks ago. Very pleased with the swap but I need an alignment to get the best out of it. It is a Magnaflow catback that came off the same car the IRS came from. The tails were pitted badly so I had them powder coated. Time will tell if it was a good idea.
The rear was complete except for the "T" fitting and short brake line. I bought the full FTBR kit as recommended by Bruce. I am going to buy the FRPP rear cover and use the bottom drain fitting to run a temp gauge.
MM parts might be spoken for once I figure out a price. If they do go I will list them.
alex302
Extra parts
What are you going to do with the extra parts? I can take them off your hands.
twovalveterror
Dayton, Ohio
I wondered how they looked so good. I've contemplated the same, but I was leaning towards getting everything after the muffler ceramic coated. if I ever go back to a rear exit system that is.
I'll have to see what the new kit includes. mine has a urethane rear bushing, and I think the aluminum would help me out a lot. but I've got a lot of little things to go over before I start swapping parts. I'm curious to see how yours does on the track, if you plan on taking it.
I really like your temp. sensor idea as well.
Gallows
Gallows
I did try to polish the tails and tips but there were badly pitted in a few places. It is a chrome color and looks pretty good but it isn't as shiney as poilished.
I can't see it going to the strip but I would like to try autocross. I missed a couple of schools on it and don't know if there are going to be anymore this year.
Duffman off of the Corral and SVTP and I were discussing temps and IRS coolers but no one knows what the actual operating temp of the fluid is so I was going to plumb in a gauge for scienctific purposes and keep a log of what temps it runs.
twovalveterror
Dayton, Ohio
I think 230(?) is the maximum safe operating temp. can't remember where I saw that. I'll be curious to see your progress on the temp. gauge.
Gallows
Gallows
or hot I guess. Good to know. I will definitely be keeping track of the temps.
I probably won't be picking up the IRS cover until later this fall or winter. I also need a set of gears (These 4:56's are noisy) so I'm keeping a lookout for a set of NIB FRPP 4:56's or even 4:30's and rebuild the carrier while it is apart.
twovalveterror
Dayton, Ohio
the noise is probably a direct result of the diff bushings. only my front two are aluminum, and it can be noisy at times. I think I'm going to try a little bit of dyna-mat or similar to quite it down. but my car is a vert and noise just goes with the territory!
then again, my car has aftermarket gears as well, so maybe the just were not installed perfectly by the previous owner.
and I remembered where I got that number from. it was in the tech info of MM's rear oil cooler.
Gallows
Gallows
The guy who I bought the IRS from said they were noisy when he had them so that's what I am leaning towards.
Was the 230f before or after the cooler?
twovalveterror
Dayton, Ohio
they claimed that 230* was the maximum safe temp. according to Ford. they said that on the track their rear end far exceeded that, pre-cooler. they never said by how much, which I found fishy, but a cooler still seems important. especially when you're running the exhaust under the diff.
Steven
SC
Hell yea! I'm glad to see its back together and some updates buddy. You make me jealous. I intend on basically the same swap but with coil overs instead and kenny brown LCA's.
Gallows
Gallows
That thing must feel like a damn rocket ship with those gears.
I thought I would see more of a difference with the 4:56's over the 4:10's but they are only slightly more aggressive.
Lol, glad someone is interested. I screwed one of my tires because of the alignment. I only put 100-120 miles on it but it sure made a mess.
g36 monkey
Orlando, Fl
I thought you were going from a stock gear (3.27) to the 4.56, but you're probably right, not an overly dramatic difference there.
I love this car though.
Gallows
Gallows
Side by side comparison of the front BF Goodrich 275/40/17s v.s. BF Goodrich G-Force TA 275/35/18
Side by side comparison of the rear Kumho V700 315/35/17s v.s. Toyo Proxy TQ 315/35/18
Still have the 1/2" spacers on and I need to pull them off and install the low profile Maximum Motorsprots IRS bolts.
96GTPlanB
