Exhaust hangers/insulator question
Venompower
Batavia, IL
Does anyone have pictures from under their car? I'm trying to see what type of hangers are used, and where they are located? My car is at the shop for a control arm install I haven't had time to knock out, and I want to order the insulators I need so I can mount the tail pipes this weekend.
RAU03MACH
NEW MEXICO
there should be 6
2 at the tail pipe
2 mufflers before axel
2 at the transmission brackets
but that's on a Flow master system , it depends on exhaust system
Venompower
Venompower
Batavia, IL
there should be 6
2 at the tail pipe
The tail pipes from LMR have the hangers near the tips and at the muffler end, so I just need to check the BBK off-road X-pipe to see if it has the proper transmission hangers.
RAU03MACH
NEW MEXICO
On the back of the transmission there should be 2 post left and right side of transmission
Some bbk will have it some won't
My off road for my 98 did not
My 95 gt dose
My bassani off road pipes had some tabs but it wasn't something that just wanted to bolt right up.
That might also because the T56 magnum in it is a little bit bigger but a good exhaust shop should have no problem, or this is a great time to learn.
nynce
