Exhaust lambda value too high
RAU03MACH
NEW MEXICO
its reading basically like potentiometer reading in current or voltage
sending signals
and you would need a star 2 tester for that
i go by fuel psi
GTamas
GTamas
Austria
How do they run the test anyway?
Tested at idle? Tested at 3000RPM? Under load on rollers? Or just holding RPM in nuetral?
Is the reading reflective of a result obtained exactly at that particular set of conditions?
They put a sensor into the tailpipe, ca. 40 cm deep. Then measure it at idle and ca. 2500rpm. Without load.
GTamas
GTamas
Austria
I checked codes... Everywhere just 111, system pass.
But I noticed that the vacuum hose on the top of this part (is it a valve?) was kinda not fully attached. It was barely connected. I know it is on the line connected to the AIR pump, but don't know yet its function. Could this be related? Maybe it was not shutting down the air feed in closed loop?
GTamas
GTamas
Austria
Well this did not solve it unfortunately. Next I will change the spark plugs and inspect the O2 sensors. I will also ask someone to do a vacuum leak test with a proper smoke machine.
GTamas
GTamas
Austria
New spark plugs did not help.
Driving a full tank on highway with premium gas and cleaner additive did not help.
Gonna replace O2 sensors next.
Also ordered an obd1 scanner to check codes. Check Engine Light flasher revealed no codes.
GTamas
GTamas
Austria
have you tried checking maff and cold air intake sensor on the air box tube
I found IAT Intake Air Temperature sensor in the manual, this is which you mean? Then I know how to check. I will have a look at it, thanks for the tip!
joemomma
They make a cleaner for them, CRC brand if I remember correctly. Just sprays on and dries really quickly. The MAF is in the air intake tube. DO NOT use anything other than MAF cleaner on it.
GTamas
GTamas
Austria
O2 sensors replaced. Lambda values did not change much, they are still around 1,6 way too lean. What do you make of the old sensors, how do they look? They are the factory installed originals.
GTamas
GTamas
Austria
So what I plan to do now:
- read codes when the innova scanner arrives
- replace the EGR valve
- smoke test for vacuum leaks with proper smoke machine (not just me puffing smoke)
- inspect/clean MAF and IAT sensors
- recheck the exhaust again for leaks
- check AIR system operation
GTamas
GTamas
Austria
By the way, there are two small holes on the stock mufflers, for the condensation water to exit. There's some exhaust gas coming out of it when the tailpipes are blocked by hand. I guess this is normal. Or what do you think?
