F cam question
  • Thread starter musclemustang94
  • Start date
musclemustang94
Guest
I wanna get an Fcam for my hot rod. does anyone know if you need to have the pistons notched for an Fcam? how much lift can u go with stock 1.6 rockers?
LAFENATU
You gotta provide a little more info bud..
What year is the car? Stock pistons? Stock heads?
Jonesy347
Had F-cam installed in my original 94 302 motor with 2.02 valves in 69 351W heads without any clearance issues. Cranked that puppy up over 6500rpm without any problems. You'll be fine with stock valves.
94Pro-5.0
Little Elm, TX
I did no notching, and have used E7, GT40, and now my trick flows with no problems.
also, don't put this cam in unless you get some upgraded heads and intakes. Get the b cam or something if your staying basically stock
kev2369
You won't need any modification for the f cam... Don't expect large power increases without heads and intake... 94-95 cars sometimes have idle issues with the f cam due to lack of vacuum and no map sensor... Good luck
94Pro-5.0
Little Elm, TX
my car is untuned and has very few issues. the small issues it has are, well small. it sometimes, right after starting will buck, but it stops quickly
musclemustang94
Guest
Its eventually gonna have edlebrock heads and stuff. Thanx for the info guys.
stang94X
my friend has a b-cam with 1.7 rockers (.510 lift) with stock heads and cleared just fine, so im sure the f-cam with the .512 lift will be just fine
